I need the pads for the bottom
foot pads
この質問は役に立ちましたか?
The lower case runs about $195 installed by DT&T services. Superglue and replacement rubber like rab777hp suggests is a whole lot easier and cheaper. Plus if you replace the lower case you could zap your board and ruin your whole day.
このアンサーは役に立ちましたか?
If you are referring to the rubber feet on the bottom of the bottom case you have to replace the whole lower case, however if they simply came off I suggest reattaching with superglue to your case, as a new lower case is expensive.
このアンサーは役に立ちましたか?
You can get them at this link for $14.95
http://www.PowerBookmedic.com/xcart1/pro...
The link will take you to the 12" feet but just click the 15" box, The URL is the same.
このアンサーは役に立ちましたか?
You have to buy a tube of super glue too.
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 1,764
