メインコンテンツにスキップ
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
My laptop is infected with the “ICSVID” virus
I dropped my laptop, and now it’s infected with the Internally Cracked Screen Virus Disease (ICSVID) virus. It will not show anything else but this. The virus is even there when the laptop screen is powered off. How can I cure it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
It’s a diseased screen.
さんによる
コメントを追加
1 件の回答
ベストアンサー
@videogamer17 this “I dropped my laptop” leads me to believe that your picture shows not a virus but a broken LCD screen. You can verify this by attaching an external monitor. If that shows a normal picture from your OS you know it is not a virus but that at minimum you will have to replace the LCD panel.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Yes, that’s the Internally Cracked Screen Virus Disease (ICSVID). A laptop contracts the virus when a user drops, hits, punches, closes the lid on something, or puts too much pressure on it.
さんによる
@videogamer17 so for this kind of virus the only cure will be the replacement of the LCD screen.
さんによる
LOL! A new LCD screen is the cure for ICSVID.
さんによる
@oldturkey03 Black “ink” spots, white/gray/black areas, lines (vertical or horizontal), flickering, and crack-like lines are all symptoms of ICSVID.
さんによる
@videogamer17 if "laptop contracts the virus when a user drops, hits, punches, closes the lid on something, or puts too much pressure on it" then yes, that will be the cure. What did your external monitor show?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Gamelover56 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 17
今までの合計 589
