"Wrong passcode" after battery replacement
I recently replaced the battery on an Apple Watch Series 4 44mm.
I removed the force touch sensor completely and did not replace it.
The Watch now shows a charging symbol when on the charger but the battery percentage stays at zero.
Also, almost every time the Watch is powered on it says “Wrong passcode, try again in 10 minutes". According to the owner of the Watch, even after 10 minutes the right passcode still doesn't work.
Should I have replaced the force touch sensor or did I aage something else?
この質問は役に立ちましたか?
