メインコンテンツにスキップ
The Dell XPS 15 9510 is a high power laptop with a 15-inch display.
2回答 すべてを表示
How do I replace display?
I would like to change from my 1080p non-touch display to a 4K option for my laptop someday. How can I do so please; if that’s possible.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
I am also considering this… but I can’t find any display assemblies for sale, even on the Dell website. Where would I buy one? Is it compatible with previous years’ assemblies?
さんによる
@zizajaun Usually takes ~6 months for the FHD LCD, and ~1 year for 4K parts.
The FHD screen tends to be a lot cheaper then 4K later on so best done new. If it cracks oh boy prepare your wallet. It's a luxury option new as it stands.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
With the XPS, the best way to do display swaps is often to change the assembly. At least internally, Dell is using different connectors on the 4K LCDs compared to normal FHD panels. As such, you usually need to change the cable and LCD. Due to that issue, it’s best to spec it out with a 4K LCD now if you can do so, or swap the assembly as a whole unit.
Typically there’s no issues on the board side as Dell uses the same board connector for the entire screen range*, so the issue is on the other side -- when you open the LCD shell.
*During the HSW (Haswell) era, there were 2 machines I know we're either LVDS or iDP based on the base panel spec/if it was for gov't or corporate customers without a webcam, but used the iDP motherboard. At one point, I used 2 of those -- an E6440 and E7440. However, Dell no longer does that and they're all iDP. These horrible transition systems are total losses now when the screens die so we just chuck them when they're LVDS :-). Good riddance.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Thanks for your help!
さんによる
コメントを追加
回答を追加する
Oluwademilade Akintan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 14
今までの合計 1,255
