Backfiring chev please help
Ok I have an 04chev Silverado 5.3L,that’s backfiring while on cruise.changed plugs and coil wires and camshaft,also changed crankshaft,and now after putting new wires and plugs it has now started flooding.what is the problem here please??
Are you sure you're using the correct plugs and that they're gapped properly? I ask because if you just changed them, and as a result it is flooding... might be something with them.
brandon k さんによる
johanneshere "camshaft,also changed crankshaft" I hope you meant the camshaft and crankshaft sensors. Have you scanned the OBD yet? Any codes?
oldturkey03 さんによる
