Why my tv won’t come on
RCA led52b45rq small red light is on. Try to power on and red light blinks and I get no picture.
@jammerso that sounds like a power board issue. Remove the back cover from your TV and (unplug your TV of course) check the power board for any obvious damage, like missing or burned components. Next you will need a multimeter to check the outputs from the power board to the main board. Check the 5V standby first. If you have that, proceed. If you do not, your TV’s issue will be a bad power board. Post some good pictures with your QUESTION so we can see what you see
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 78
2 件のコメント
@jammerso how many times does the right light blink? Is there a pattern to it?
oldturkey03 さんによる
It only blinks once
James omerso さんによる
