Can I fix a shaking image on my C434T Asus Chromebook?
My chromebook screen image began shaking. Everything else seems to be working. I tried powerwashing it as was suggested in my research but that didn’t work. Is there something else I can do?
Hi @lunapuna,
Try connecting an external monitor (TV?) to one of the laptop's USB-C ports (USB-C to HDMI converter) and check if the display is steady or not.
If the external display is OK it may be a laptop LCD panel problem or a video cable problem.
Try gently moving the lid slowly back and forth to a position where it doesn't occur. If the shaking stops it may be a damaged video cable or just a loose connection, either on the motherboard or the display
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 211
3 件のコメント
What is power washing?
mike さんによる
@aactech
Powerwash
Cheers
jayeff さんによる
Hi @jayeff
Thanks so more marketing word change game.
mike さんによる
