メインコンテンツにスキップ
Officially marketed as Nerf Blasters, Nerf guns are toy weapons made by Hasbro that fire foam darts or, in some cases, foam balls.
How to disassembly Nerf Elite 2.0 Commander RD6?
My son won a Nerf Elite 2.0 Commander RD6 in his birthday, but the trigger does not work. I would like to know how to dissassembly the toy correctly to fix the trigger.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hello, these videos may help to disassemble
  1. https://youtu.be/qO0Tj7WLAaQ
  2. https://youtu.be/K1LHeQBZr7I?t=28
This site is also informative: https://www.reddit.com/r/Nerf/comments/h...
And these videos may help to repair:
  1. https://youtu.be/N8JpePwvuHw
  2. https://youtu.be/KVR_KlwBUuc
I’m assuming you have this model:
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Those last 2 videos are for the disruptor.
さんによる
yes, though I still find them very helpful, as they are quite similar to your model. :)
さんによる
コメントを追加
That's awesome that your son won the Nerf Elite 2.0 Commander RD6 for his birthday! It's a bummer that the trigger isn't working, but don't worry, we can fix it. To disassemble the toy correctly, start by locating and removing any visible screws on the blaster using a screwdriver.
Once the screws are out, gently pry apart the sections of the blaster, being careful not to force anything. As you take it apart, remember to keep track of the pieces so you can easily put it back together later.
For more detailed instructions and helpful tips, you can check out https://nerfinfo.com. They have a wealth of information that can guide you through the process step by step.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nink さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 117
今までの合計 7,653
