メインコンテンツにスキップ
The Samsung Galaxy A10 is an android smartphone developed by Samsung Electronics. It was released in March 2019.
20回答 すべてを表示
What are these parts on motherboard?
After water damage, I replaced the LCD and the battery. The phone seems to work perfectly, but there are two metallic shields on the motherboard that get hot when the phone is turned on, but in standby. I want to soak it in isopropyl alcohol, but I am curious what are those metallic shields covering? Do I have to remove them to have better access?
Link for an image that shows the metallic shields: https://vrm24.com/media/Motherboard_2_Z0...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@forzal those are EMI shields. They are usually desoldered. You can use a hot air station or a very large tip on your soldering iron to do so. Of course you can always use some cutting instruments like some sharp scissor. Check videos like this to get an idea how its done.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you very much!
さんによる
コメントを追加
回答を追加する
Laszlo Attila さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 8
今までの合計 88
