Does any one know where the fuel filter on a 2000 Honda Accord Lx is?
I have been looking for hours for my my fuel filter location and I just can’t seem to find it.
It doesn’t have one:
このアンサーは役に立ちましたか?
@ceenobi52 the strainer at the fuel pump should never really give you any issues. I am certain you will have your fuel pump fail before the strainer is going to be an issue. Some of the Honda do have another fuel filter but it is very model dependent. What engine size is your Honda and what are the symptoms that makes you think it's the filer?
I have a 2.3, so on a cold start it’s start to get shaky until u give it gas, I’ve recently changed the distributor and intake
@mayer so is it connected to the fuel pump?
@ceenobi52 does not really sound like the filter. Could be an issue with the MAF or a vacuum leak. Lets see if we can narrow it down
@oldturkey03 I doubt it’s a vacuum leak cause like I said I’ve already changed the intake. What is the MaF?
It is in the trunk in a hole attached to the fuel pump
このアンサーは役に立ちましたか?
It's a bag attached to the fuel pump
So it ended up not even being the fuel pump, my radiator was clogged @Seth Shapleigh
過去 24時間: 3
過去 7 日: 13
過去 30 日: 46
今までの合計 1,651
