メインコンテンツにスキップ
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
327回答 すべてを表示
we turned on pc yesterday and it booted to bios wont even turn on now
basically we built my dad his pc everything worked just fine yesterday it posted and went to bios but now when we try to turn it on to try to install windows it wont power up at all except the fans spin barely and then stop motherboard has power and lights are working but for some reason the system wont power on except the small fan movement and stop we pulled battery out of motherboard and replaced it any other suggestions gpu is in socket good everything is plugged in so it should be powering on nothing has been changed in bios
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
選択されたソリューション
Hi @chanman2399,
More information is needed to help you.
What is the make and model number of motherboard and the make and model of the PSU? Also the amount of ram and GPU information (if separate GPU card) would help.
Try connecting a system speaker (example only) to the motherboard's system speaker header pins and check if there are any POST error codes. Check the mobo user manual for location of pins. If there are any codes heard, search online for (insert make of motherboard) POST error codes to see what they mean.
Try disconnecting all non essential components e.g. HDD/SSD, ODD and any other add on cards so that you have a barebones PC i.e. mobo, ram + CPU, PSU, GPU card (or integrated), monitor and keyboard and then try to start it and get into BIOS.
Test the PSU using the paperclip test to make sure that all the voltages from the PSU are OK.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
jayeff thanks for responding we figured it out the psu kept shorting because we were using sata cable from another psu and kept shorting it
さんによる
コメントを追加
回答を追加する
wesley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 51
