KDL 32L4000 Picture has lines and appears “hazy”
Picture is watchable but have started getting lines. Makes picture look “hazy”. Doesn’t extend all the way to top. Replacement t-con (used) improved it to this.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@jimgmaker that looks like an issue with the LCD driver board (for all intent and purposes) that is a part of the panel. Since you already changed the T-Con board, your next step would be to check all the ribbon cables to make sure that they are seated right and clean all the connectors.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 115
