メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
iPhone 4 home button works poorly after a small water spill?
Hey all,
New to this site, can't believe a great site like this exists!
So here's my problem...
My girlfriend spilt water on her iPhone 4 (GSM) just so its clear.. about 4-5 months ago.
Ever since the water spill, the phone's home button does not work well.
What do I mean? - Well it does work, but only if you press on it quite hard, specifically the pressing has to target the center upper edge of the button. That is the only way it is functional at all. As you can imagine doing a "hard reset" is a HUGE pain in the butt, because you can never be sure if the home button is activated or not.
I was wondering if simply buying a new home button from this great looking site, along with any other necessary materials will be sufficient to fix this problem?
Well thats about it..
Looking forward to your answers,
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Replacing the home button should work for you.
My problem was similar. After almost a year of use, the iPhone 4 home button became less responsive. I had the phone sent for repair and moisture was detected inside the device. As the warranty was void, I decided to replace the button myself. It works like a charm now, responsive as on day one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I got the same problem, where was the moisture found? On the home button, or on the sensor for the home button? Is this package enough? [リンクされた製品が存在しない、もしくは無効: IF182-017]
Thanks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No idea. All I know is the moisture sensor was triggered. This package should be enough. In case it turns out not to be, you could try replacing the dock connector as well.
さんによる
コメントを追加
not working at o cant turn on after water
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
If the issue started after water damage you probably only need to disassemble the phone and clean the contact points between the homebutton flex and the connector on the dock connector and clean the back of the button and the frame contact point. This fixes 90% of them.
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 7,388
