メインコンテンツにスキップ
ジョイコンは、ニンテンドーSwitchゲームコンソール用のコントローラーです。
Right joy-con shell does not close well after replacement of joystick
I have replaced my right joy-stick according to the instructions on this website. However, when I place the plastic case back on the joy-con, I find that it does not close properly on the side of the rail. It should be tight fitting but there is a clear gap:
I wonder if anyone had the same problem and knows what can be done to properly close it. I thought maybe that the problem originates from the plastic battery case already not closing entirely well, but the screws for that part go in properly without any force.
As a sidenote: The joystick does work, but to calibrate it I need to apply force with my fingers around the joystick, otherwise it doesn’t recognize the joystick during the calibration itself.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I have repaired quite a few of these without issue now, in this case I would say you have probably gotten either a defective part or you have not quite seated it correctly in the case. I would strip it back down remove the joystick and start again, then you can be sure everything is as expected.
Here is the video I made sometime ago on how to do it: https://youtu.be/pVH802ss_08
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Aimée Kok さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 949
