メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
A14 Bionicプロセッサ、10.9インチのスクリーン、新しいデザイン、ボタン式のTouchIDを搭載したiPad Airタブレットです。2020年10月に発表。
Why my ipad air wont turn on?
It was suddenly a dead battery so tried to charge it but after a few hours, there’s no charging logo and won’t open by pressing the top button. Left it overnight charging, still the same but it did heat a little, maybe it means it is charging. My charger don’t have any dust and can even charge my samsung type c phone. Also done the force reset but still wont open. Anyone who knew whats the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
i have the same problem too. i sent it to the nearest Apple service center in my place and they said that they need to replace the whole unit because the ipad has no screws thus making it impossible ‘‘for them’’ to open/repair but only if its covered by the warranty. im still waiting for the diagnostics results and i’ll update you asap.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Update!
My ipad replacement was confirmed. They are going to change it. Dont worry cuz its covered by the warranty. Dont do DIY battery replacement! Just give it to apple service and let them do it. My ipad just finished its diagnosis and they didnt even tell me what the problem is, im pretty sure its a hardware probelm. And dont worry cuz u wont spend a penny while they replace it. Thats all.
さんによる
I'm assuming your iPad Air 4 was still covered by the warranty. The question is, what to do after the warranty (and implied warranty) has already expired.
さんによる
コメントを追加
Try replacing battery
you can do it DİY if you want İf you wanna pry on a LOT OF adhesive
if not logic board may be suspect
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Found a cracked ipad air 4 for sale
https://www.ebay.com/itm/185166679277?ep...
should do the trick just remove its battery
if it still wont work logic board(you may lose data)
if still broken,charging board is dead
さんによる
@zygrei07 get off ifixit
İfixit is for right to repair/diy repair community
さんによる
コメントを追加
回答を追加する
Desiri さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 54
今までの合計 1,117
