My Camera and type cover not working Surface pro 4
I got a case of camera not working on surface pro 4 device. It happened after I replaced the digitizer screen.
At first it was always flickering, so I replaced the lcd, then after replacing it I found a case whose cover type couldn't be installed, then added a camera that didn't work by displaying the error code "0xA00F4244", I've been trying for a few days by following the instructions circulating on Internet. But did not find a solution.
Using utility software, I found 3 camera errors even though all drivers were installed. and it says 'error code 10". and I tried to fix it using utility software and only two work, while main camera shows error message.
while I was repairing, there was a small "tick tick tick" sound on the logic board. Not sure where it's coming from, but heard in the block area leading to the camera socket.
- The area I marked in yellow is where I heard a "tick tick tick" sound during the repair process.
- On red, it looks like a diode, but not sure which way to go, and it shows short circuits on both legs.
Is there a solution here?
thank you
