メインコンテンツにスキップ
The Motorola X Sol Republic Deck is a bluetooth speaker designed by Motorola, released in August 2013.
12回答 すべてを表示
My deck got wet. Is it salvageable?
So, my toddler sprayed my motorola x sol republic deck with the hose. I turned it off immediately and let it dry for about 2 months before turning it on.
Since then, it will connect, but it seems like there’s a short circuit now. If I adjust the volume using the deck’s buttons, it will power down. And the sound cuts out so frequently you can’t listen to anything. Is it salvageable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@nosh27 this “let it dry for about 2 months “ possibly corroded some of the components on the circuit boards. Use these guides Sol Republic Deck and try to take it apart as much as you can. Clean the boards with a soft brush and some high-grade isopropyl alcohol. Check for burned-out or damaged components. Post some pictures of your boards etc. so we can see what you are looking at. After it is all cleaned of any corrosion, replace the battery as well and see what you get. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
nosh27 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 36
