メインコンテンツにスキップ
2020年11月に発売されたPS5コンソールは、大幅にアップグレードされたビジュアルと革新的な新Dualsenseコントローラーを特長としています。最先端のブラックホワイトのデザインは過去のPlayStationから大きく脱却しました。
PS5 SSD installation - replacement screw and spacer
I tried to install a new WD SN850 SSD in my PS5 last night. However when I went to remove the screw and spacer in the bay, the screw was stuck, and I just can’t remove it at all. I’m looking for a replacement screw and spacer to fit the SSD. Does anyone have any recommendations from Amazon UK or any other retailer? I’ve contacted Sony, but they haven’t got back to me at all, which isn’t a good sign. Many thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
9 件のコメント
I got the same problem too. Currently trying to find similar screw and spacer in SEA market but can't find nothing
さんによる
@Akifan Jannata I still haven't had a response from Sony Customer Support. I'd happily buy the screw and spacer if I knew what I was looking for! So frustrating!
さんによる
Hi i have the same probleme if one of you find the good dimension for the screw can you tell me
さんによる
To replace the screw that holds down the M.2 access cover, use a M3 × 16 screw.
To replace the screw that holds down the M.2 SSD drive, use a P3 × 10 screw.
To replace the spacer that supports the M.2 SSD drive, use a spacer with the dimensions φ5.5 x 3.95 mm.
さんによる
Where do they sell the spacers? I can't find it with an internet search.
さんによる
4件以上のコメントを表示
コメントを追加
5件の回答
ベストアンサー
I have found a screw that has done the job for me. I got the M3-0.5 x 10mm flat head phillips screw, which fits perfectly. I didn't need a spacer either. The screw did the job on it's own. Hope that helps
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
From which UK shop?
さんによる
I ordered a new screw and spacer on Amazon. So am I good to just leave the stuck/stripped one in it’s original 110 slot?
さんによる
コメントを追加
This is the screw I replaced the original stock screw inside the ssd bay that holds down the ssd.
Update (06/05/2022)
This is the original screw that came with the ps5 that I damaged.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
4-40 x 1/2 in. machine philips pan head screw fits inside the original ps5 spacer
さんによる
さんによる
コメントを追加
Here are images to see that the 4-40x1/2in. screw fits inside the ps5 ssd bay.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Bro what is the size of screw you displayed in 2nd image
さんによる
Is the screw properly fixed with ssd?? And what's the size of it?? Plz inform me Asap.
さんによる
Sorry for the late reply. The screw size is 4-40x1/2in screws.
さんによる
コメントを追加
https://amzn.eu/d/iJrAFeV
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I found this on Amazon UK, "Amazon's Choice" for ps5 ssd screw and spacer
DevineCustomz® Compatible For PS5 Mounting Solid State Disk SSD Screw Replacement Nut Console Motherboard Metal Screws
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kevin McCubbin さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 55
過去 30 日: 223
今までの合計 38,261
