New battery but still won't charge. Is this an I/O board problem?
I replaced the battery just fine but the new one will still not charge. The power cord and adapter are good.
I/O problem or what else could it be ??
It looks like your logic boards charging logic has failed as your battery current charge is 2050 mAh, yet your charger is connected but not charging! Unless you only just connected the MagSafe charger and the logic hasn’t flipped the ‘Charging with’ and the value ‘0 Watts’ is also altered to a value.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 78
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法
That should give us a clue on what's happening here.
Dan さんによる
