メインコンテンツにスキップ
フィットネストラッカーシリーズ「Fitbit Charge」の第3世代。
22回答 すべてを表示
My fitbit charge 3 is different?
As you can see in the image my fitbit charge 3 has three ribbon cables coming from the screen where the one of the teardown has only 2. My replacement screen also only has two. Can anyone explain this? What kind of connector is this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Are you sure this is an authentic fitbit? it could be a knockoff that for what ever reason needed another cable
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I am 99% sure. I also just found the box and it states that this is a special edition with fitbit pay. Maybe that the pay mechanism needed the extra cable, and it makes sence that this is mounted under the glass since the signal doesn't transfer through metal. Also the replacement screen works even without the extra cable!
さんによる
コメントを追加
You have a special edition Charge 3. You see them on occasion. If you have the sticker on the back of the screen, that should be removable and then you can apply it to the back of a replacement screen. Otherwise, ignore it and the payment option will just stop working. It's not a big deal if it does so unless you have a use for it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Niels Fennema さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 318
