メインコンテンツにスキップ
The Ford Focus is a compact car (C-segment in Europe) manufactured by the Ford Motor Company since 1998. The Ford Focus ceased production in 2018.
184回答 すべてを表示
My back driver side door will not lock or Roll down the window
OK I bought my 2013 FORD FOCUS ST about four or five months ago car is great everything is great everything works just fine besides my back left door I’m not so sure if it has anything to do with the motherboard. I tried using a code finder on my car to see if there was an issue with it but nothing showed up and there is no error codes or anything. I can’t roll down the window nor can I walk but when I do lock my car from the outside all the doors were locked except for the back left but if you were to open the door the alarm will sound which is good still but it’s still not help the fact that somebody can easily just ignore the alarms they don’t give a $@$* and go steal my stuff that I do not want. I am partly mechanically inclined I know the basics like changing oil and breaks is there something I could try that may or may not work or maybe even reset the locks on the door in the power window I know how to reset power windows in general but whenever I did that they would reset and continue to work as properly auto rolling down and so on and so forth except for the back left and still did not reset when all the other windows reset. Also my middle lock button inside my car does not unlock the doors I tried looking up a reset on how to reset that but I could not find anything even on the focus ST help websites such as this one. If anyone knows of any little ways I could try and reset them on my own please help had this issue and has gotten it fixed and knows a way of getting it fixed involving a mechanic or yourself please send a message as well.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Christian, I’m having the same problem. Did you ever fix this?
さんによる
コメントを追加
1 件の回答
Have you checked to see if you're getting 12V to the door? Could be loose plug, damaged wire/pin, something like that. Check to make sure you're getting power to the door. I've also been reading that there's a rear panel that has control modules, and one for that door should be there as well. Might want to look and see, make sure that it isn't a bad module. Also check to make sure you're getting good ground, otherwise the power has no return path. Start there, let us know what you find.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you for the fast response ok I will try that and let you know.
さんによる
コメントを追加
回答を追加する
Christian さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 17
今までの合計 746
