My screen popped out
Dropped my Apple Watch and the screen popped out. It separated below the gasket and touch sensor as the screen an touch are still working even while separated from the phone. Anyone else experienced this? I’m stumped.
This happens more often than you would think. Unfortunately the adhesive is the only thing that holds those screens in place and they degrade over time. This happens quicker if you are in a warm environment often, a sauna, in direct sun, or if it's getting wet often. This can be repaired but due to the age your best option might be to replace it as the repair is likely to cost you more than it's worth.
From what you have described all you may need is the force touch sensor adhesive gasket (14.99) but finding a shop with a low service charge is the issue.
Good luck and hope this was helpful
このアンサーは役に立ちましたか?
I have the same problem the screen popped out but the force touch sensor adhesive gasket remained intact. Including a picture for reference
このアンサーは役に立ちましたか?
You need to get a new force touch sensor adhesive gasket.This will have the new adhesive you need to stick your screen back down.
I have one that came with the battery kit, but it does not cover the area that is broke. The original force touch sensor adhesive gasket is still in place it never came undone.
Did you get this fixed? I have the same problem
I did not. It would have required a battery replacement and someone to press fit it back in place. It would no longer be water tight which is huge problem for me. So I just replaced it.
過去 24時間: 14
過去 7 日: 51
過去 30 日: 256
今までの合計 13,121
So you need new adhesive?
Andrew S さんによる
Thanks for responding Andrew. This one is weird.
The normal adhesive strip is still connected to the face and the force touch. The watch separated below the force touch. I can lift the screen and everything works. After examining, there was no adhesive where it separated. I popped the face back in and it held together for about a week or so then came loose again. I purchased new adhesive strip but there was no rim to place it on. Like I say just weird. Any thoughts would be greatly appreciated. Steve
Stephen Cook さんによる
@sacook818 Could you take a picture? iFixitでの質問に画像を追加する方法
Andrew S さんによる
I will. I popped it back in for my wife so she could use it. The next time it pops out I’ll send some pics. Thanks
Stephen Cook さんによる
Side note: makensure your battery did not expand. In most case of iwatch screens lifting, the battery expended causing the screen to lift and would need to be replaced first
Innovatrix Repairs さんによる
3件以上のコメントを表示
