メインコンテンツにスキップ
2012年11月2日に発売された第四世代のiPadです。16、32、64GBモデルがあります。モデル番号はA1460です。
20回答 すべてを表示
ipad 4 shutting down or restarting every 3 minutes
so i have this ipad 4 and the problem is, at first it died from overuse, drained battery, i decided to try and shock the battery with a power supply and it powered on, but the problem is, i accidentally broke the flex that connects to the main board and the gsm or cdma board. but the ipad still powers on but it restarts or shutdown every 3 minutes. i ordered battery online and tried replacing the battery but still the same. it restarts and most of the times, shutdowns on 3 minutes. could the broken flex be the one that was causing the shutdown or restarting?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It’s hard to say with 100% certainty, but I doubt it.
I’m pretty it would just cause certain reception functions not to work.
I would highly reccomend to back up, update, and or restore before continuing your physical investigation.
Rule out software, then parts, then motherboad in that order is the way to go from my experience.
If yoy already did that, then look into the batttery connector, solder connextion, and near by components for damage. A bad connection on the battery data lines will cause it to turn off on it’s on after a few minutes
Let us know how you do with the update and or restore.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
morph alucard chua さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 84
