メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年10月発売のGoogleのPixel 4 XLスマートフォンのリペアガイドと解体情報です。
Pixel 4 XL motherboard battery connector repair is impossible?
I tried soldering for battery connector fpc self-repair.
However, there was a problem removing the original fpc parts, and it was further ruined while trying to solder them.
Is it impossible to repair my motherboard in the picture?
And can you introduce me to a repair shop that can be repaired?
I have a new battery connector fpc part and a new battery.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
2 件のコメント:
I need the jumper
さんによる
i need the jumper also pls
さんによる
コメントを追加
2件の回答
I see that the pad is missing.
This should be fixable by soldering a mirco wire to what that pad was connected to and soldering the fpc connector back on that cable.
In some cases, some pads are no stuff. Meaning there where not used in the end design and there for does not matter that it is missing. That is less likely for a battery connector
Any shop that specialises in micro soldering should be able to fix this for you.
Our shop does it if your interested. We are situated in Canada. Innovatrix Repairs.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Is that two power ways for the battery
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kieun さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 31
今までの合計 2,116
