メインコンテンツにスキップ
Repair guides and support for the OnePlus 5T, an Android smartphone with a 6.01" AMOLED display. Released in November 2017. Successor to the OnePlus 5. Model number: A5010.
35回答 すべてを表示
Dropped phone - Turns on but has no display
Hi :)
I have dropped my phone flat on the screen. It fell on the floor and after that the display went all black.
However, those are still working :
  • Charging light
  • Buttons
  • Touch screen (I managed to turn off my alarm with my finger)
I already dismantled it and verified if the connectors were well plugged : they are now and still no light… Have I missed something? Should I buy a new screen?
Many thanks !
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
As a DIY repair all you can do is to change the display assembly and check.
Here’s the Ifixit OnePlus 5T AMOLED Screen & Digitizer Replacement guide that will help you to do this.
Note: Ifixit has the display assembly available (click on parts in the guide)
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hello Jayeff,
If I understand, changing the screen is to you the only way?
Regards,
Félix
さんによる
@KasDing
The phone has an AMOLED screen so there is no separate backlighting for the display as the pixels provide their own light.
Whereas an LCD display uses backlighting and it may be a backlight power problem on the systemboard and not in the display assembly so you could try shining a torch at the screen to see if there are any images at all, just not seen because of no backlight proving the problem into the display or the board.
It's a shame that you can't get to the Settings and setup screen mirroring from the phone to a TV for example. that way you would know whether the problem is in the display or the systemboard.
To do board level fault finding to know whether the problem is in the display or the systemboard you would need the schematics (I can't find them online) and some test gear.
As I said for a DIY repair replacing the screen is the first best option. They're more fragile than the systemboard as for the phone being dropped that is ;-)
さんによる
Argh ! Seems pretty clear... I will order a new screen then.
Many thanks to you @jayeff for all the time you spent answering me :)
さんによる
コメントを追加
回答を追加する
KasDing さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 64
今までの合計 1,880
