Should I shut my phone off before replacing the battery?
Should I shut my phone off before replacing the battery? Also can I replace it when the battery is completely drained or should I charge it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Zoe,
When doing ANY phone repair always power off the device first before tearing into it. After you tear into your device the first thing you always do is disconnect the battery cable to reduce the risk of possibly shorting anything out during a repair. The percentage of the battery does not matter when you’re going to take it out of the device. The only thing that matters is you properly charge the phone to 100% after installation.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 20
今までの合計 318
