メインコンテンツにスキップ
15インチディスプレイのMacBook Proモデル
8255回答 すべてを表示
How many is too many charging cycles for a laptop battery?
I'm thinking abut buying a used early 2009 Macbook Pro 15 at a college sale, so these will have been used by different students (one student per laptop though).
I have a 2006 Macbook Pro 17 that has 454 cycles, and using terminal it shows the "MaxCapacity" = 4746, "DesignCapacity" = 6300. It lasts a couple hours still, but when it dies, it is unable to sleep, and just shuts down. I'm hoping to avoid this with the newer laptop. So I'm wondering what the threshold is for replacement (so I can add that to the price if needed).
To see what your battery cycles/capacity are, in terminal use: ioreg -l | grep Capacity
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I found Apple's guide on the matter, gonna take this with me.
さんによる
コメントを追加
4件の回答
ベストアンサー
Variations in use and manufacturing likely make purchase decisions based on cycles probably a bad idea. what if you only discharge halfway? What if you drain the battery until the laptop dies everytime? What if you operate in greatly varying temperatures? Is the laptop in your backpack getting banged around often? All these things have the potential to reduce battery life. Really you just want to find the laptop with the least use (if possible). And hey, worst come to worst, we have plenty of guides for MacBook Pro 15" to help you swap the battery quick and painlessly!
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
最も参考になった回答
For our stocking purposes, after about 200 cycles you'll see decreased performance and over 500 may need to be replaced. But this is mostly bad info.
What you really want to look at, are the mAh (milliAmp hours) numbers you included which is basically a count of the number of electrons that the battery can contain.
So your battery can hold ~75% of the electrons it used to be able to. It should be replaced, if possible.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I've got a 5 year old Macbook 15" with 1653 cycles that lasts a number of hours (never bothered to check) before running out of battery. iStat claims the battery to be at 92% health...
Any thoughts on the matter?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Only thought I have is that 1653/365~=4.5 years, that means you've managed to fully charge the battery (assuming that OSX is accurately calculating cycles) almost every day for the life of that laptop. Nice work (I think).
さんによる
コメントを追加
several laptop manufacturers estimate that you should get 300 to 500 charge cycles before the battery begins to fail; some may even promise 1,000 cycles.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Collin Reisdorf さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 8
今までの合計 15,436
