メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2614回答 すべてを表示
Tv has no picture but has sound
On a Samsung UN50EH5300F the tv turns on and has sound and I can see the menu with the flashlight test and after checking the pins for the backlights the one ones the ones with voltage were
  • D+ had voltage
  • D+ had voltage
  • S1- no voltage
  • S2+ no voltage
  • NC no voltage
  • S2- no voltage
  • S3+ no voltage
  • D- had voltage
  • D- had voltage
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Shorting together connectors 2 and 3 fixed my issue of my backlights not turning on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Dark Nation let us know what voltages it did show you and how you measured it. If your voltages are within acceptable parameter I would turn my attention to the backlight strip. Common issues with Samsung at those models. Of course you can test it by disconnecting the main board from the power board. That will force your backlights on. So if they do not come on you know the issue are the strips.
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
my volt meter is very hard to read the volts but it read somewhere from the range of 200 - 250 and both D+ measured voltage while grounded and I could read voltage on both D- when reading with either of the D+ and vice versa
さんによる
Ok voltage seems a little low but it should power up your backlights. Did you disconnect the main board from the power board? Did the backlights turn on?
さんによる
Sorry for a late response but the voltage for them are around 330 range for only both D+ and disconnecting main board did nothing
さんによる
Okay since your voltage is good and the disconnecting of the main board did not result in a working backlight, the issue appears to be your backlight strips. Time to replace those.
さんによる
I may have given you some bad information or something but the issue seems to have been my power board or something but I’ve found that shorting connector 2 and 3 together fixes the issue I was having
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Dark Nation さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 138
