When powered goes to sensing fill and stays there, WTW4815EW1
With water in it, if powered on goes to sensing fill flashing doing nothing. If cancelled it makes a humming noise from control panel. Had emptied it and was able to run calibration. Then ran clean and full of water and same problem. need to get to hardware store to get hosing for pump to pump it out. Hoping to solve issue now if possible. Is there some way to manually force it to drain? I have very hairy dogs and most wash is their blankets. When drying I get handfulls of hair in lint trap. Thinking maybe drain pump clogged with hair. Whirlpool HE WTW4815EW1
Was able to pump out to toilet nearby, with pump. Ran automated diagnostic and passed. It does not drain though. Shouldn’t the test check for that? Not draining is what I think the problem is.
Any suggestions on what to check?? Does back panel have to come off, or is everything done from bottom. Hoping back panel since very small room and may have to drag into yard to access bottom.
