メインコンテンツにスキップ
The RIDGID R84015 X2 is an 18v, 1/2 inch chuck, cordless drill.
Chuck is stuck and will not turn
I went to use my drill the other day and when I went to put a bit in the teeth, the chuck would not move. I could not get the teeth to move at all, and the chuck would not turn. I thought maybe it was just stuck and thought about putting something in there to loosen things up, but my father-in-law was afraid it might get into the electrical parts. Any information on how to get this unstuck would be helpful. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
This is a notorious problem, (you'd think RIDGID would have something on their website) but the solution is to slightly turn the rear collar to open then put a 7/8" wrench on the shaft behind the collar and finally, carefully turn the chuck CCW with a pair of pump pliers avoiding scoring it.
さんによる
Doug.. GREAT... Did as you described and was able to open and close the chuck jaws.. so I can get a bit in and out.. Won't be needing to do much drilling so your help save me a bunch of $$$....
Thank you
さんによる
コメントを追加
4件の回答
ベストアンサー
Matt, on your chuck the rotary action of the outer body which acts on an internal screw; this in turn moves the threaded jaws in or out along a tapered surface. So, if any of the jaws, has jumped the thread, it will create a wedge and stop the chuck from moving. You can try to hold the drill with the chuck down and gently tap it with a small hammer (or the handle of a screw driver :-) and see if it will free the jaw. Otherwise, I would think it is time to replace the chuck. It is held on by a bolt right in the middle of the chuck. No electric parts are directly involved with this. Replacement parts and a diagram are available right here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
That worked. Thanks for the simple fix.
さんによる
I had no idea how to get it to move.
I turned it down, several taps with a small hammer.
Round she goes. Yay! Thank you!
さんによる
On my Ridgid #5010 hammer drill, there is a small hole like where a chuck key would fit. I lubed it several times with a penetrant/lube (3 in One, first, then dome Red-Armor from Ace hardware) and it worked for me!
さんによる
コメントを追加
I have the same B&D mains! What happens to these chucks is the end up with dust from drilling masonry! Never try to Grease the chuck. use and releasing fluid WD 40 or generic. Spray down inside the chuck. Place a spanner on the the nut at the the back of the chuck , it requires a standard open Jaw spanner I used a 3/4 Af. Take circular wrench and hold it on the outer side on the chuck and gently turn counter clockwise! Chuck to you right spanner on the base of the chuck and turn the out case of the chuck away from you gently! Then give it regular clean with releasing fluid!
Regards. Fred.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This worked. Thank you and WD-40!
さんによる
コメントを追加
Take it back to the store Rigid tools have lifetime guarantee
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
life of tool only I recently had them not honor warranty on 3+ year old cordless drill with a frozen chuck
さんによる
コメントを追加
Removing and installing r5010. 1001
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matt さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 63
過去 30 日: 248
今までの合計 100,521
