メインコンテンツにスキップ
AppleのiPad AirのWiFiモデルのバージョンはモデル番号A1474、スペースグレーと、シルバーがあり、カスタムA7プロセッサーが装備されており、容量は16、32、64、128GBがあります。
300回答 すべてを表示
iPad stuck in update mode, can’t even get in dfu mode
my home button was broken a while ago and I tried the other ways of getting in dfu mode nothing worked, I plugged into iTunes for windows and it still didn’t detect it, since i have to tap trust computer, which I can’t do cause I’m in update mode, it’s been stuck like this with the progress bar not even showing a pixel of black(the progress bar), at the time of writing, also when I plug it into iTunes it gives me error 0xe8000065 after a few minutes
EDIT: I have now gotten the iPad to the plug into iTunes black screen but on the middle of updating, it disconnects and says error 2003
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You need to do a hard restart but with home button not working you can not do it you can try . But if you keep screen lights on and kill the battery then bring itunes up plug dead ipad into your computer when it boots itunes should catch the update and repair the problem with update but with home button not working last time i saw that the battery was leaking acid in the bottom of ipad you should lift screen and look if you dont know how take it to a place that replaces screen and ask them to look in it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Void4Games さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 86
