メインコンテンツにスキップ
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
104回答 すべてを表示
My anti theft AND door ajar light on the dash
In my 2006 ford escape sometimes it won't start. I'll turn the key over and have power but won't start. It has no crank. I've noticed that the anti theft light flashes. I've read in owners manual and it says that mean there could be a problem. I've read all these different articles on how to deactivate it and have tried them with no luck of any of them fixing it. It dawned on me that everything I read started with “make sure all the doors are closed" as i see with my 2 eyes yes they all are closed….. but the car thinks one is open. On my dash the door open light is on. I have narrowed it down figured out that my light gate is the door the car thinks is open. And thats where I'm stuck! How do I get the door ajar on my dash to go off so I can fix the anti theft????
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @foreverlala ,
Not sure what you mean by “light gate”. Do you mean the lift gate at the rear of the vehicle?
Here’s a link that may help. door open light goes on and off and alarm off and on
Click on the link in the Chosen Solution.
It may only provide a temporary solution but at least it should prove that the lift gate door switch is the problem.
Here’s a video that shows how to access the door lock that may also help if you need to replace it. I realize that it is for a 2001 model but I think that it should be the same for your year model.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Michele Le Anne Bradley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 525
