メインコンテンツにスキップ
2019年5月に発売されたAndroidスマートフォンのOnePlus 7 Proです。
Half of my display is dead
After a fall, my OP7Pro started acting up. Wouldn’t turn on for a while, but that eventually worked itself out. Now though, the bottom half of my display is dead - by which I mean, the bottom half of the screen is black, but the phone still registers touch on that half of the screen (albeit unreliably). I get the occasional flicker of the actual display too, though this has been happening much less often now.
From watching teardowns, I have no idea why only one part of the screen would be dead. I thought it might be an issue with the optical fingerprint scanner, so I tried taking that out, but still the same problem. Any idea what I might be able to do to fix this?
EDIT: forgot to mention, I’m also getting “ghost touches” in around the middle of the screen, between the working half and non-working half. Happens mostly on the left side of the screen. Don’t know if that helps to figure out what’s wrong/broken.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
oled display is cracked, replace it
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Not the answer I was hoping for, given the price of those screens… thanks though, at least now I won't be holding out for a cheaper repair
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Michael Murphy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 50
今までの合計 1,238
