メインコンテンツにスキップ
A 15 inch laptop made between 2013 and 2015 by Dell computers.
Fans not switching on after cleaning them?
I removed my fans to clean the inside of my laptop, after putting them back in they won't run. I can put them in but not all the way, but then they run at full speed permanently. I've tried changing the settings to passive and not active but still nothing has changed. The moment I switch my laptop on the fans run at max speed…I don't want them running at max. Please could someone assist me?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
What do you mean by "I can put them in but not all the way" ? What is "them"? The fan connectors? The fans themselves?
さんによる
The connection. If I hold the connectors and it just just touched the port then the fans run at max. But when I insert the plug securely then the fans do not work
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi @logank02 ,
Here’s the owner manual for the laptop.
Go to p.24 onwards to view how to remove and replace the fans.
They need to be seated properly otherwise the airflow from the CPU & GPU may not be good enough to extract the heat fast enough. The CPU has an internal thermal sensor (don’t know about the GPU but it most probably has one too) and that is most probably why the fans are on high trying to cool them down as best they can.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi thank you. I've actually posted this for a friend. I showed the manual to him and he says that he has inserted the fans correctly. I think the best thing to do, is to get someone to look at it and see what he has done incorrectly.
さんによる
コメントを追加
回答を追加する
Logan Kirchner さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 19
今までの合計 396
