メインコンテンツにスキップ
Sonyのワイヤレス・ノイズキャンセリング・オーバーイヤー・ヘッドホンWH-1000XM2の修理・分解情報です。
7回答 すべてを表示
Earpiece broken from headband at the swivel joint
As too often happens with kids in the house, one kid left these headphones on the floor, another accidentally covered them with a blanket, and a third stepped on them. ??‍♂️
It seems the problem is the plastic swivel joint connecting the ear cup to the headband. Does anyone have any advice on conducting all repairs or information about the replacement part number(s)? Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Taylor Williams that swivel does apparently not come as a spare part. I would get something like this and replace the part that holds the speaker since it has the swivel in it. I have not had any luck with any adhesive on headphones. Adhesive just does not have the flexibility to keep those parts from failing again.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have this same problem and wondering if the parts from the XM3 in oldturkeys post worked for the XM2?
さんによる
コメントを追加
回答を追加する
Taylor Williams さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 10
今までの合計 1,168
