メインコンテンツにスキップ
Appleによって、2018年10月に発売された第3世代高性能のタブレットです。モデル番号はA1876、A2014とA1876です。
64回答 すべてを表示
Replacing Face ID Flex Cable on iPad Pro 12.9 Gen 4 via ebay
Hi,
I have seen many people selling flex cable which is on the back of lcd of an ipad pro 2018 and 2020 models. Do they require any special programming or you can just attach them back to the new lcd ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Just be aware that by replacing components tied to FaceID will result in the loss of FaceID. The components are programmed to each board with the use of a special tool only apple has. But you should be able to replace it nonetheless. You’ll get a message when the device turns on stating “apple is unable to activate FaceID”.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I understand that however I could not find any guide about ipad pro 11 or ipad pro 2018/2020 getting their face id flex cable ( the one attached to lcd) being replaced. only 1 video I could find on chinese video https://haokan.baidu.com/v?vid=123967644...
I wonder how that works because I didn't see any programmer being used here to reprogram new flex cable.
さんによる
@imab I have absolutely no idea what they're talking about in that video. If they replaced the flex cable and maintained FaceID, then they must've transferred the components to the new cable.
さんによる
@hootonberg ok I ordered that proximity sensor cable from aliexpress seller but when I attached to my ipad it started a bootloop. I had to remove it to make ipad restart. I do not know why it is not working.
さんによる
@imab I would try another proximity sensor then. Sometimes people sell junk parts, especially on AliExpress and eBay. I know in the case of the iPhones if that assembly is shorted out it can cause a bootloop as you mentioned.
さんによる
コメントを追加
https://www.youtube.com/watch?v=8X20TVVf...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
imab さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 37
今までの合計 1,471
