メインコンテンツにスキップ
The Ford Expedition is a full-size SUV assembled by the American automaker Ford Motor Company. Introduced as the four-door successor of the two-door Ford Bronco, the Expedition has remained in production since the 1997 model year; it is currently in its third model generation.
77回答 すべてを表示
How to hook up my alternator to battery on ford expedition 98
What are steps to connect alternator to battery on 98 ford expedition ? Tried everything changed solenoid , alternator, battery, cleaned terminals and expedition will not start when turning key it just makes click sound
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Nicole Gonzales this does not sound like an alternator issue per se unless of course your (new) battery is empty. Check the battery connectors post and see if the wires are corroded etc. Let us know if your vehicle starts with a boost from another vehicle etc. Try to use a multimeter and check to see if you get power to the starter. ALWAYS MAKE SURE THAT YOU SECURE THE VEHICLE SO IT DOES NOT ACCIDENTALLY MOVE!!!! Check something like this and let us know what you find out. Ultimately a quick attempt to hit wire the starter will show if that works. If so you need to check the starter relay and see if you get power to that.
Let us know what engine you have in your Expedition so we can see if there are any know issues with it
SInce you specifically ask for the wiring here is the wiring diagram for a 1998 Ford Expedition
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Nicole Gonzales さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 12
今までの合計 253
