メインコンテンツにスキップ
The Samsung Galaxy A30S is a phone released by Samsung in August of 2019. It came with Android 9.0
81回答 すべてを表示
My phones half screen is work and half is purple
in early morning my phone have a full orange screen which does not work .now after some time screen is devided into two parts one part is work with some bugs and other part is purple. and do not work. please tell me how to fix it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
6 件のコメント
My phone display was broken
さんによる
Sorry to hear that, Maaz. What do you want to do?
さんによる
My phone screen is doing things to itself, and it says it's broken
さんによる
ALI king where and what does it say about being broken? Does it do this all the time or only sometimes? When does do it things by itself? Need more info here.
さんによる
Display broken Display broken Display broken Display
さんによる
1以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
narenda modi sounds like your display is failing. Of course if anything else happened to your phone like water damage etc. this might change. From what you are describing I would suggest you replace the display assembly and re-evaluate. Use something like this video to work on it.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If your phone's screen is bleeding purple, this indicates it's been severely damaged. The screen has cracked internally, and the LCD fluid is seeping freely. Unfortunately, there's not much that you can do about it. The only solution is to replace the display.
Hope this helps
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
narendra modi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,325
