メインコンテンツにスキップ
Repair Guide and Support for Lightning McQueen RC Car toy. 1:24 scale RC car from Dickie Toys. Article number(s): 203089501 for basic Lightning McQueen 203089538 for metallic variant
8回答 すべてを表示
Rear wheels have no traction
So my young son has been obsessed with removing tyres from his vehicles and Lightning was no exception. After 2 years of losing the tyre it was found again but now lightning has no rear traction on smooth or carpeted services. I've cleaned out dirt, used wd40 to lubricate but to no avail.
What am I missing? I've never worked on a RC car before so conplete rookie.
Thanks for your help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
7 件のコメント
Hello! Does the car have traction with all of the tires placed on the wheels?
さんによる
Sadly no. Wheels spin fine when in the air but car doesn't move when on the ground even on smooth surfaces.
さんによる
@Claire Dombera So the wheels will not spin when they are on the ground?
さんによる
They try but can't move even with new batteries.
さんによる
They kind of vibrate
さんによる
2件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Unfortunately, due to the information you have provided above, it sounds like your toy car has a bad gearbox motor or a bad axle. You can find replacements for these online, and I can help diagnose the problem further if you open up your toy car and send a picture of what it looks like.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Thank you. I'll send images tomorrow. :)
さんによる
It looks like the gearbox motor inside of your toy car has been stripped. These are very cheap to replace.
さんによる
So sorry I completely missed this answer. Thanks so much Bob. Let me try and find one. :)
さんによる
@Claire Dombera I'm not sure what Bob is seeing. The gears all look fine, though the loose strands from the wires attached could be causing an issue if they're shorting out the current... with it open and in the air, make it run. Then, set it down, and look inside and try again, watching what is moving inside of it. Might be a problem with the motor internally.
さんによる
コメントを追加
Sorry taken me a while to work out how to post pictures :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Claire Dombera さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 24
今までの合計 422
