メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPod screen replacement pops up
I replaced the screen and made sure I did not have any ribbon cables in the way of the emi shield but the screen just slightly pops up on 1 side? does it have something to do with that metal plate?
here are pics
http://i485.photobucket.com/albums/rr220...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
PREP,PREP,PREP!!! iPod 4 screen replacement is all about the surface preparation before the new screen is installed. Make sure the digitizer cable is folded the correct way. if you cant get it to stay down and you are sure the cable is folded, place a teny tiny bit of super clue in the ip 2 corners. No more problems.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It looks like it's more than slightly popped up.
It might be you don't have the digitizer cable folded properly.
There is alot of discussion about this. Look over the q&a's.
No doubt you took it apart again. Did you figure it out?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the same problem but I had the screen replaced and after that I dropped it again. The screen is still ok but it seems I dented the backplate too much and now my iPod touch 4 doesnt respond the way it should. Like I would click "A" and it would touch a button far from it. I'm Planning to get the back fixed for 30 :/
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shan さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 9
今までの合計 1,831
