メインコンテンツにスキップ
15インチディスプレイのMacBook Proモデル
8251回答 すべてを表示
Replace glossy display with antiglare?
I have a Feb 2011 15" MacBook Pro Glossy (no high-res) display. I'd like to swap the glossy display and replace it with an antiglare.
If I take a 15" antiglare from a Mid-2009 15" - MB986LL/A MacBook Pro, and swap it with my 2011, will it work? Does Apple use the same wiring/cables?
Also, if not, will a 2010 display work on a 2011 MBP?
And will I have to install any additional drivers or color profiles to make it work?
Does the color profiles just automatically get downloaded, or will I have to copy it from the old machine?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Thanks for your response.
Another question, what about the facetime camera? Doesn't the 2011 display clamshell have a "Facetime HD" camera while the older MacBook display's have a regular iSight camera?
さんによる
You could always just add an anit-glare screen protector...?
さんによる
コメントを追加
3件の回答
ベストアンサー
Yes you can you can replace the LCD you speak of with any and all of the LCDs you mention. The LVDS/video cable is the sane for all of them, see for compatibility list of the cable. There is more information on the compatibility of the screen here and here. You will need to reset your SMC and PRAM after the exchange. Instructions for doing that are here and here. Resetting the PRAM should take care of color and resolution changes.
Added With Edit
To address the question in your last comment: Apple handles the cameras through USB emulation. The connector/socket for the camera is just a funny looking USB port. As long as the connector on the wire fits in the socket it will work as originally intended.
Based on that comment I think you are really wanting to exchange entire upper assembles between the 2 laptops, which is slightly different than your original question and requires a number of different considerations to be addressed than those posed initially ie: Are the hinges the same and are they going to line up and mount the same?, Are the wires for the camera and wireless going to be long enough and mount the same on the logic board? etc....
If the hinges are the same but mount slightly different, this will not work. etc...
To exchange entire upper assemblies you will need to make sure the hinges will align, mount the same and are the same distance from the upper edge from the top of the lower case. You will need to verify that the camera and wifi cables are the same length and connect the same. Since you have booth laptops there you are the most qualified person to determine these things.
MacBook Pro 15" Unibody LVDS Display Cableの画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
この回答は他の質問に帰属しています。
See this Question
If this answer was helpful please remember to return an mark it Accepted.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I know that's old, but hi-res connector are different from standard resolution display...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Igor さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 4,266
