メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
Facing No Service Freqently
Hi Team ,
i am facing No service Frequently ,
let me know if any solution available ,
the thing is i asked many technicians but they are not giving any guarantee instead of that they are saying that it may dead if they do any thing,
please let me know any possibility there to get it repair done ,because its gifted by mother since i am using this mobile from 4 years ,no repairers instead this only one issue,
Thanks in advance
Bharath.A
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If you've tried resetting network settings or completely wiping the device and the issue is still persisting, then it is likely a failure on the hardware side and you should get a reputable repair shop to diagnose the problem. Usually this will be done by a professional under a microscope, and they'll be able to tell what the issue is and how much it'll be to fix(if possible at all). Back up your data and try to identify if it's software related first though, however if it isn’t, it'll be a bit trickier and more expensive to fix unfortunately.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
i Tried it several Times Liam ,But No use ,can you suggest anyone who will be able to resolve the issue ,
Basically i am from india ,if they will repair it, i can ship my mobile to there place
さんによる
@avulabharath Here is a link I found through about 2 minutes of googling, however you could probably spend a little bit more time searching to find a better or faster service.
https://www.irepair.in/irepair-doorstep-...
さんによる
Hi Liam Thanks For Your Information ... I will Follow Up
さんによる
コメントを追加
回答を追加する
BharathReddy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 90
