メインコンテンツにスキップ
The Logitech Dual Action is a USB, PC controller for gaming. Model number: G-UF13A.
17回答 すべてを表示
My controller keeps disconnecting
So basically, I’ve been trying to play games with my controller, and it only SOMETIMES connects, and if it does it’s only for a split second, I think it might be because a bit of the special uhh, whats it called? protective case of the wires is exposed, like the white stuff, it’s from the Kittens I have.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi Joshua!
Basically it means that you need to replace the cable. I would replace it first and see how that goes.
Just get the glue off and de-solder the cable. Make photo’s before you proceed as you need to know which color goes where. It will not be easy to find the cable (part).
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Sorry but that doesn't help much, I have no idea how to do these things, I think I might take it to my step-brother, he knows how to do these things I think, he is currently replacing the loose battery on my 3DS, so Ill ask him about this and see if he can help me.
さんによる
Hi Joshua! Sry for the late reply.. Yes you can ask him to replace it if he is able to find the part.
さんによる
コメントを追加
回答を追加する
Joshua Durbidge さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 14
過去 30 日: 23
今までの合計 560
