Can jailbreaking will fix error 29?
i replaced my old battery with a new one, it works for about a week,then when i upgraded to os5 in itunes, i ended up in error 29, my device is iphone 3gs 16gb
この質問は役に立ちましたか?
この質問は役に立ちましたか?
pollytintop, do you remember the fix suggested by Majesty a while back that would prevent iTunes from communicating with Apple servers? I wonder if that would help, if it has to do with apple recognizing the OEM (or not) battery. Why do I receive error code 29 when I attempt a restore? Also, I believe that OS5, even so apparently compatible with the 3GS, is still having to many issues. I'd wait for another update :-) So downgrading is probably the best solution.
このアンサーは役に立ちましたか?
just recently used that on an ios 5 update that went horribly wrong..on a 3gs! OT3 good call. It just makes itunes resend info instead of using archived stuff (I think). This is on the apple support website/advanced troubleshooting section which I can never seem to find..
Error 29 is most often a Hardware Error. It is an Error that you hope is due to your new battery being incompatible with your iPhone. If it is not due to incompatible battery, it is most often means a significant Hardware Error.
このアンサーは役に立ちましたか?
I see a few error 29's and this is software and hardware
Restore it in DFU mode
To get to it, plug the phone into the computer and reset it by holding home and power together
Let go of power and keep holding the home button, it will say "iTunes has detected a iPhone in recovery mode" and click restore
If this does not work, it hates the new battery
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,301
1件のコメント
think you need to downgrade not necessarily jailbreak, unless that is what you want to do? This is probably apple recognising an oem battery, so you'd need to try a restore to your previous ios..hopefully saved somewhere??
pollytintop さんによる
