メインコンテンツにスキップ
Repair information for impact drivers.
32回答 すべてを表示
Trigger not triggering impact driver - how to diagnose/fix?
My erbauer impact driver started having intermittent problems where the trigger would t trigger the driver. This has gradually got worse, no it never works.
it’s not the battery, that works in the drill fine.
I’ve squirted contact cleaner in it, no joy.
you can see the problem in the video, you can see how the contact light flickers, it’s like there isn’t enough contact to get the thing going.
im not knowledgable enough to know what this means or how to diagnose it further.
Anyone any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Hi @tofuwarrior,
What is the model number of the drill?
さんによる
Hi,
Thanks for answering.
I think it is ERI604IPD
The I might be 1.
It also says 15W45 00398
On it.
But I’m guessing the first one is the model.
Cheers,
Paul
さんによる
Nu este asamblat bine acxul cu csneluri!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Could be a bad switch "trigger" . I suggest you take it apart and use a multimeter to check the switch. You can of course never rule out a bad motor but for now I put my money on the switch.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi @tofuwarrior ,
I agree with @oldturkey03 about the trigger switch most probably being the problem.
I can't find your model listed here but it still may be worthwhile contacting them and asking if there are any parts available for the drill.
さんによる
@jayeff @oldturkey03 , thanks very much for your advice and link to that supplier. I’ll find out how to check the switch using multimeter and see where we go from there ?
さんによる
コメントを追加
回答を追加する
Paul さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 21
過去 30 日: 66
今までの合計 1,152
