The phone won’t charge
i attached the image of what exactly i think is causing the phone not to charge, but im not 100% sure if that’s the problem. had this phone for YEARS so im sure there might be other things wrong. what can i do to fix this?!
That definitely shouldn’t be bent like that, I suppose you can Try very carefully bending it back in place with a very small tool as a solution and see if that works, other than that, completely replacing that connector entirely may be possible, though it is directly connected to the mainboard.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 46
