メインコンテンツにスキップ
Appleによって、2018年10月に発売された第3世代高性能のタブレットです。モデル番号はA1876、A2014とA1876です。
64回答 すべてを表示
IPad Pro backup problem
Hi.
I have an iPad Pro model 2018 - 12.9 inches.  I try to backup all the data I have on it.  But about a year and a half ago my screen was partially broken, but the screen works just fine.  And I also think that the charging port has been damaged with the time I’m using it.
Because every time I connect it to a computer to backup the iPad then the computer does not recognize the iPad at all, not even with another cable.
 So my question is, how can I backup my iPad if the charging port is screwed, and the screen is broken so that it is also problematic to replace a charging port without also replacing the screen, something I do not have money for at the moment.
I would be happy for your help please, because it is very very important for me to backup the data I have on the iPad.  I would be very happy for your help!
TY ALL!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
You use iCloud. If the data is that important to you, a few dollars per month is nothing.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Ty very very much buddy!
さんによる
コメントを追加
I don't know if this will work for you. There is a free iPad backup tool called MobiKin Assiatant for iOS. You may try it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
I.k さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 9
今までの合計 57
