メインコンテンツにスキップ
The Samsung Intercept SPH-M910 is a midrange Android smartphone sold by Sprint, marketed as a newer, more affordable version of the popular Samsung Moment. Released in 2010 with Android 2.1 Eclair.
6回答 すべてを表示
How to replace the flex cable
i took my samsung intercept in to get repaired.they told me it was the flex cable that needed replaced and wanted to charge me 79.00.So now I am researching on how to do this myself.I have already ordered the flex cable.I now just need instructions on how to replace it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
scott, check on here for the Incercept SPH-M910 disassembly. Hope this helps to get you started.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Same problem here, and the dis-assembly article does not go that far. Between step 8 and 9, there could be more detail showing how the LCD flex is mounted to the keyboard slider. The flex terminates on a board which is attached to the keyboard slider mechanism. This ebay listing http://www.ebay.com/itm/Flex-Cable-for-S... (or search ebay for m910 flex) shows the board. It is mounted with pins and adhesive and pops out.
さんによる
コメントを追加
回答を追加する
scott さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 735
