Why are the fans still running and the cars off and cold
The fans keep running after the key comes out and locks the door flattening the battery everytime. Help what's wrong please
check the coolant temp sensors and see if there faulty first, check your fuses and make sure there all okay and that the wiring harness that is plugged into the sensors and the fan module behind the radiator are all okay and no signs of anything loose or broken. when you drive the car is the coolant temp within normal range?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 66
