My lower burner has quit heating.
Can this be repaired by replacing the heating fuse.?
Could be a fusible link. Could be the heating element itself. When I replace one I normally replace the other at the same time, if the equipment im working on has both. Check and see. You'll have to open it up. Disconnect both ends of the element and do a continuity check. If no continuity then it's a ad element
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 15
今までの合計 379
